delfinis38
Sump pan and gasket for a vr
You can still get the gasket from VW, but they're £40 odd! I bought a Victor Reinze one from ECP so good quality for about £16. Not sure about the sump, but I just got a good used one. Alternatively the alloy sump from a v6 4mo Golf I believe also fits, but is shallower and you'll need a new pump as well to fit.
24v sumps fit with no mods. R32 sump would require a pump change.
iirc the R32 sump doesnt use a rubber gasket, rather a sealant (available as a tube of).
Same with the 24v..... works a treat :)
Ahh thanks for clearing that up Chris.
No worries.
To the op, there is an ali sump for sale on here currently. I went for this mod and its just great.
I seem to recall not all sump bolts would fit into the bellhousing, or some parts around the bellhousing weren't accessible, although it was quite some time ago. Did you find the same?
I removed the bell housing plate, which was 3 bolts, to allow access to the remaining sump bolts. All very easy stuff mate.
