nrc 0 Posted September 19, 2013 After the upper windscreen trim as a careless window fitter managed to break mine and then go on to fail to seal the screen properly... :mad2: Part number is 535 853 307A 01C Ta! Neil Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted September 19, 2013 As far as I know, the trim is the two side parts and then the long plastic trim that goes all the way around. I have one of those if you need it. Ron Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted September 19, 2013 The bit I have is No 14 on this diagram http://www.vwparts2go.com/oem-part/volkswagen/corrado/1993/slc/2-8l-v6-gas/body-hardware/windshield-glass/reveal-molding/535853307a01c Quote Share this post Link to post Share on other sites
stevec14 10 Posted September 19, 2013 Hi Check out ebay item number 121149417540. Might be what you need. Quote Share this post Link to post Share on other sites
paddy26 3 Posted September 20, 2013 You could also try these: http://www.arz-tuning.de/shop/index.php/cat/c97_Corrado.html I've got a few bits from them before including the windscreen trim. I haven't unwrapped it yet as I haven't got that far in my build. \Paddy Quote Share this post Link to post Share on other sites
nrc 0 Posted September 30, 2013 Thanks for all the replies and sorry for the delay in responding; for some reason email notifications weren't on. The bit I have is No 14 on this diagram http://www.vwparts2go.com/oem-part/volkswagen/corrado/1993/slc/2-8l-v6-gas/body-hardware/windshield-glass/reveal-molding/535853307a01c It's #15 I need, the plastic trim bit that goes along the top of the screen. Hi Check out ebay item number 121149417540. Might be what you need. Looks like it might have the right bit and worth a punt at £13 with the delivery. You could also try these: http://www.arz-tuning.de/shop/index.php/cat/c97_Corrado.html I've got a few bits from them before including the windscreen trim. I haven't unwrapped it yet as I haven't got that far in my build. \Paddy Yep, they've got it here. Will probably go here if the trim from ebay turns out to be wrong! Quote Share this post Link to post Share on other sites
