robdriver
ENGINE CONVERSION- fitting ABF into Corrado 2.0 8V ADY 1996
I have been doing a bit of research on installing the ABF 2.0 16v into my Corrado 8v
My car is one of the last made fitted with the Mk3 Golf 2.0 8v 115ps lump and it seems that the ABF goes straight in onto my original gearbox. I am very happy with the current motor as a daily driver but as its approaching 180000 miles it will need refreshing sometime
I just missed an auction to buy an engine but it was because I was worried as the what parts I need to get from the donor car
What do I need from the donor car
Engine only ...... I believe my box fits ABF fine......is this correct
Engine ECU ...... do I need to take the ABF engine ECU and wiring harness........
key ...............do i need the ABF donor car ignition barrel?
exhaust............does the ADY exhaust fit the new ABF manifold
clocks.............read somewhere that my clocks are fine with ABF engine
engine mounts......will the standard ones fit
BONNET.............I have the late model bonnet
is there anything else I need to know to do this conversion and would you recommend it or suggest I rebuild by stock 8V engine instead
