MurdoMac
Which flywheel cover plate?
Just noticed while changing my gearbox oil that my flywheel cover plate is missing and would like to replace it but am confused as to which one it is, P/N 096409157B (this one http://www.ebay.co.uk/itm/181245058018?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649) or P/N 068103648C (this one http://www.ebay.co.uk/itm/400474607256?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649)? car is a 2.9 VR6 manual, I havent been able to see the gearbox code even looking at the wiki page pictures of where to find the code although it's probably right in front of me, any help which is the right part most appreciated, thanks.
Hello there,
I've just got in from being out on the town, so bare with me.
This part number 096409157B
I think this is the lower flywheel cover plate off a 4 speed auto gearbox
(CFF) & (CLB) Auto boxes VR6 Golf, Passat, and might be in Corrado also.
This is another part number 095409157
Which again is the lower flywheel cover plate off a 4 speed auto gearbox.
This is the part number I think for the lower flywheel cover plate,
on a VR6 Manual gearbox. Part number: 02A 301 157C
This cover plate looks similar to the auto one,
well it might even be the same but may just have a different part number,
simply for the auto box ?
Manual box lower cover: 096409157B
Auto box lower cover: 02A 301 157C
VR6 (ABV) - (AAA)
The lower flywheel cover plate on the Corrado 4 cylinder engine,
is I think part number:
038 103 648A
For engine codes:
(KR) - (9A) - (2E) - (ADY) might even fit the (PG)
Then the large one above that behind the flywheel is.
Early spec to >> 1991 - 1992: 068 103 645A
Later spec after 1991 - 1992 >> 068 103 621E
For engine codes:
Engine codes of MK2 Golf / Scirocco / Passat.
(PL) - (DX) - (EX) - (KR) - (9A)
and many more of the 4 cylinder engine lower flywheel covers should be inter changeable I think.
Also there's a small cover plate at the back of the engine,
that is bolted to the front face of the bell housing just above the O/S/F inner driveshaft flange.
This cover / dirt plate simply fits into a clip at the bottom and then is held in place by a 6mm bolt with a 10mm hex head.
This cover plate hides the back of the flywheel and stops any dirt or small stones,
from making there way in to the bell housing where the flywheel / clutch are.
The same with the lower cover plate, simply protects the flywheel / ring gear.
Plus this is only for the Corrado with 4 cylinder engine.
Part numbers for this small cover plate are.
Early spec cover plate to >> 1991 - 1992: 068 103 648
Later spec cover plate after 1991 - 1992 >> 068 103 645M
gasket for both is: 037 103 649
6mm bolt with 10mm hex head: N 0102085
6mm spring washer: N 0122265
The manual gearbox 5 speed in the Corrado is normally the 02A box.
1.8 16v (KR) had box AGC (Late 1988 to Mid 1990)
1.8 16v (KR) had box AGC >>91 / 91>> CES (Mid 1990 to Late 1991)
1.8 G60 (PG) had box ATB (Late 1988 to 1990)
1.8 G60 (PG) had box AYL / AYN (Late 1990 to 1991)
1.8 G60 (PG) has box CBA (1991 to Mid 1992)
2.9 VR6 (ABV) had box AGK (Late 1991 to Mid 1992)
2.9 VR6 (ABV) had box GHN (Mid 1992 to mid 1995)
2.0 16v (9A) had box CES (Late 1991 to Mid 1992)
2.0 16v (9A) had box CGY (Mid 1992 to Mid 1995)
The gearbox code numbers are stamped in the alloy casing,
or are stamped on a alloy plate that is riveted / bolted to the casing.
This is normally near the diff almost level with the speedo but on the other side of the casing,
just above the N/S/F driveshaft flange close to where the rear gearbox mount is attached,
or can be close to the slave cylinder, left side of it.
Hope this helps.
Right I'm off to bed :sleeping: :lol:
Si
Wow, thanks that is pretty comprehensive.
Ive got 1 if you want it for £10 posted?
if so then yes £10 posted would be great pm me you payment details and i'll get it sorted, thanks.
The d shaped part I have, unsure what the bar underneath it is. Ill pm you now. I can collect it from my unit Thursday night if you dont mind waiting till next week for arrival?
No worries, glad you've found the part you need.
I made a mistake on my original reply,
the part numbers should be:
Manual box lower cover: 02A 301 157C
Auto box lower cover: 096 409 157B
VR6 (ABV) - (AAA)
Cheers
Si
