howlingvr6 0 Posted November 22, 2013 All of a sudden it wont start. It turns over and fires up for a few seconds and just dies, I have noticed a squealing/whistling noise as I turn the key, I think this has some relevance to the problem. Sucking air perhaps? Have looked for the obvious things like holes in pipes and have cleaned the AFM with carb cleaner..Any ideas anyone ???? :-( Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted November 22, 2013 Immobiliser ? Quote Share this post Link to post Share on other sites
howlingvr6 0 Posted November 22, 2013 Clifford concept Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted November 22, 2013 Just sounds like a classic immobiliser problem with the car starting then cutting out after a second http://the-corrado.net/showthread.php?t=55219 try Second post on the above link from the late great Chris Gaskell (RW1) Quote Share this post Link to post Share on other sites
kerrly 0 Posted November 22, 2013 yep my old clifford would do that and my current corrado immobaliser tries the same from time to time. Do you have a functioning 2 button switch on your dash and the pin number to manually override the alarm? Quote Share this post Link to post Share on other sites
Jim 2 Posted November 22, 2013 I'm going to lay a bet that this is the classic built in immobiliser problem. It's been discussed on here many, many times... Example discussion on what needs doing in this thread and should hopefully be enough to get you started in doing some searching on everything you need to get it fixed :) http://the-corrado.net/showthread.php?t=55219 Quote Share this post Link to post Share on other sites
howlingvr6 0 Posted November 22, 2013 I have had reader coil problems in the past which I fixed using the WD method and the symptoms were similar, but this time the engine is running for a slightly longer time ( 1 sec), its not an immediate shut down. It seems that this is an air or fuel problem to me but who knows at this stage. Kerrly mentioned the override option,... I tried this last year and the code thats written on the Clifford handbook does not seem to work. Will have another look at the reader coil tomorrow and keep you all updated. Thanks all for the help,much appreciated :0) Quote Share this post Link to post Share on other sites
howlingvr6 0 Posted November 25, 2013 Ok everyone, broadband now back on so I am able to give you the good news. I thought it would be wise to check the fuses as a basic non expensive remedy and yes it was fuse No. 16 (15A) which is the fuel pump (HP). Looking at the fuse map on the tray you pull out, the fuse for the fuel pump is No.18 and No.16 is for warning lights. Can't understand why this is but the car is now running fine. Thanks for the help. Happy Corradoing :-) Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 26, 2013 Glad you got it sorted . Quote Share this post Link to post Share on other sites
