stevec14 10 Posted January 21, 2014 Hi All. Would like to change the roof mounted bee sting aerial on my Corrado as the reception is useless with amplified signal cable plugged in or out. It currently has the original amplified type. Can't make up my mind at moment do I stick with the standard bee sting look or upgrade to a nice Oe Vw/Audi sharkfin type aerial. Has any one changed their aerial for an aftermarket one? And more importantly do they work better than standard? Please post up your pictures showing what you got. At moment I can't decide between a Hirschmann bee sting and an OE VW/Audi look sharkfin(both amplified). Also what size is the mounting hole for a standard Vw aerial base? Thanks Steve Quote Share this post Link to post Share on other sites
Diamond Hell 0 Posted January 21, 2014 Get a late Polo stumpy one from VW. Stumpy OEM goodness. Quote Share this post Link to post Share on other sites
southerner88 10 Posted January 21, 2014 Just an aftermarket one from my old valver, looked pretty good on a black corrado... [ATTACH=CONFIG]77205[/ATTACH] [ATTACH=CONFIG]77206[/ATTACH] Quote Share this post Link to post Share on other sites
buttles 0 Posted January 21, 2014 http://www.dabonwheels.co.uk/Kinetic_DRA-6001_FM-AM_DAB_car_aerial.html Direct fit in hole but you need to run two cables forward to head unit. 12v and FM lead. Quote Share this post Link to post Share on other sites
fendervg 30 Posted January 21, 2014 I have one of the shorter arials and it updates the car nicely. Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted January 21, 2014 Does the shorter one just screw into the original base. My aerial has a crack in it so I could do with a new one, I'm liking the look of the shorter one. Rog. Quote Share this post Link to post Share on other sites
Diamond Hell 0 Posted January 21, 2014 Certainly does - to show it on my C I unscrewed it from the Passat and screwed it on! Quote Share this post Link to post Share on other sites
stevec14 10 Posted January 22, 2014 Hi All Thanks for replies. But just to clarify I need a new base as well as a new aerial. The base unit amplifier is u/s, and the radio reeception is very poor. So looking to replace the whole aerial system. Has anyone replaced their aerial with a VW/Audi Oe shark fin? If so can you please post up a picture. Thanks Steve Quote Share this post Link to post Share on other sites
Diamond Hell 0 Posted January 22, 2014 Shark fins on cars this age just look chavvy. Just replace the base and top with the Polo unit - subtle update that doesn't shout 'I have an aerial for navigation but couldn't arrod a car new enough to have navigation'. ;) Quote Share this post Link to post Share on other sites
fendervg 30 Posted January 22, 2014 The newer aerials carry the current for the amplifier in the base over the aerial cable, the older ones like mine have a seperate live feed that plugs into the base - so check what you have and make sure you get the correct one. You can get bases and aerials all over the place. Quote Share this post Link to post Share on other sites
fendervg 30 Posted January 22, 2014 Check this thread out: http://the-corrado.net/showthread.php?t=19671 Quote Share this post Link to post Share on other sites
stevec14 10 Posted January 23, 2014 (edited) Thanks for post Looking at hirschmann aerials there are some on Egay check out item number 380394350703. Compared to stealer prices they seem a bargain at £37. Look Oem also Hirschmann aerials are very good had one fitted to my Mk1 golf many years ago(wing mount). Very good reception. Does anyone know if they fit? Steve Edited January 23, 2014 by stevec14 Quote Share this post Link to post Share on other sites
MZpog 10 Posted March 14, 2014 Thanks for post Looking at hirschmann aerials there are some on Egay check out item number 380394350703. Compared to stealer prices they seem a bargain at £37. Look Oem also Hirschmann aerials are very good had one fitted to my Mk1 golf many years ago(wing mount). Very good reception. Does anyone know if they fit? Steve fitted one of these last night, fantastic recommendation, the radio picks up stations I didn't know existed Quote Share this post Link to post Share on other sites
