renson 0 Posted January 27, 2014 I have noticed that the nut/bolt holding the ball joint (mounted onto the end of the wishbone)into the hub has broken. I need to get a replacement to put in until i get the car into a garage. Does anyone konw the size and length of this bolt? Thanks for the help in advance, Darren Quote Share this post Link to post Share on other sites
paddy26 3 Posted January 27, 2014 Are you talking about the 3 bolts that hold the ball joint to the wishbone? If so, it is 25mm long. M8 thread. 13mm head. The bolt that holds the ball joint to the hub is 50mm long, M10 thread and 16mm head. You get them all from the dealers for cheap. \Paddy Quote Share this post Link to post Share on other sites
renson 0 Posted January 31, 2014 Thanks for the reply......... had one in my box of many corrado spares and managed to get it done once i knew :) Quote Share this post Link to post Share on other sites
