Alty
Alloy Radiator?
Anyone fitted a alloy rad to a G60 if so did you adapted the orignal fan onto the rad or did you buy an universal one ?
This is the one ive been looking at on ebay : http://www.ebay.co.uk/itm/ALUMINUM-ALLOY-RADIATOR-VW-CORRADO-SCIROCCO-JETTA-GOLF-GTI-MK2-1-8-16V-1986-1992-/281166739477?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3ACorrado&hash=item4176d7f815
Thanks in advance
Scott
Only ever seen slimlines fitted to them, I guess you could refit the fan cowel if you get the rad to same dimensions.
That rad looks upside down for a G60 though, the return bleed would be at the bottom and the fan switch will be up at the top near the charger.
You need the fan switch at the bottom :)
