Panici 10 Posted February 6, 2014 (edited) Hey guys, Pulling the VR6 out of our '97 mk3 jetta to do a clutch job. What else should we be doing while the motor is out? We just bought the car, history is unknown. Motor has 360k km (220K miles) on it. Should we be doing a rebuild while we have it out? Plan is to build a track car. Thanks! Edited February 6, 2014 by Panici Quote Share this post Link to post Share on other sites
Stonejag 10 Posted February 6, 2014 It's probably only got 12 valves ;-) Has it had the chains done? Might as well while it's out. Quote Share this post Link to post Share on other sites
seanl82 23 Posted February 6, 2014 Pulling mine next month. Plan on crank seal, (my reason for pulling it), New oil cooler and seals, crack pipe and seals, inspecting chains and tensioners (done 10k ago but worth checking regardless), I've done rocker and sump gaskets 3k ago so that should be ok, inspect core plugs, and anything else that looks a little dopey before painting it all up and chucking it back in. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted February 6, 2014 Tis the season to pull engines out it seems! What's next? Everyone pulling out dashboards? Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted February 6, 2014 yes on crank seal and timing chains/guides/ re seal timing chain casing, Quote Share this post Link to post Share on other sites
clumpy1 11 Posted February 6, 2014 Tis the season to pull engines out it seems! What's next? Everyone pulling out dashboards? Funny you should mention that it's another job on my list to pull out existing dash and put in replacement oh that and pull out engine and a few other bit's and bob's....... Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted February 6, 2014 If it's anything like mine, the only thing left not touched on the entire car is the shell (needs bodyshop) and the steering group column (probably has play in the top knuckle!) Quote Share this post Link to post Share on other sites
seanl82 23 Posted February 6, 2014 Tis the season to pull engines out it seems! What's next? Everyone pulling out dashboards? Been there, done that................. Quote Share this post Link to post Share on other sites
