teveO
g60 will not idle once warm
hey guys just wondering if anyone else has had the same problem,
i can start the rado from cold and it will idle slightly high until its warm which is normal but if i take it for a run until its at normal working temp, turn it off and leave it for 10 min and start it, it just bounces from 0 to 100 rpm sometimes cutting out? unless i rev it for 20 sec from start and release the throttle it then idles (just):scratch:
cheers in advance
steve
I had this problem and it turned out my vacuum pipes on the back of the throttle body needed swapping round, could also be a split vacuum pipe causing odd readings
Thanks for the reply I will check this today, anyone have a description or drawing of where the pipes go to and from thanks
