quicky1980
323mm brake discs
cant find a sensible answer anywhere.
does anyone know if there are 323mm discs with 5x100 PCD but with a differenct offset to the 312mm 4motion discs? My brembos wont fit behind the wheels but if i can get the disc to sit deeper in towards the car then I may be able to get enough clearance
cheers
You can buy disc/bell setup with the bell made to your spec, depends on your budget - as that's expensive.
Seat Leon Cupra R setup uses 323mm discs for the Brembo config.
Have you tried this option...?
Disc's aren't cheap tho.
Thats pretty much what he has, they use the same offset. I had a kit on my Mk4 and it wouldnt work on the Corrado because of this.
Hey. I have Porsche 4 pots on my Rado and running 323mm. As above im running the Seat leon Cupra r discs. You will be limited with wheel choice with these brake upgrades though so beware! Im running Audi tt comps and only have a few mm to spare!
