Kevin Bacon
Brembo pad question
I'm changing the pads on my mate's Cupra R tomorrow. Is there anything different about doing this on Brembos over standard brakes? I'm sure there isn't but thought I'd check as I know some of you have this setup on your cars.
Cheers
K
I'd guess that if anything it's easier 'cos the caliper is just held on with a pair of bolts into the mount rather than into the sliders, so you'll only need a single spanner to get the caliper off... 8)
I didn't have a look when I fitted mine as to how you get the pads out of the caliper, but I can't imagine that it would be that difficult... :?
He he, took me an hour!
I have *got* to get some Brembos....mmmmm. They are sublime. They come apart like Lego. Well easy to do.
Seat wanted £150 for the pads and £30 labour. Feck that. He got some Mintex pads from Euro Carparts for £30 and an hour's free labour :lol:
The nutter had killed his pads inside 19k!
I take it on the Corrado conversion you just cut the brake wear sensor wire off yeah?
Cheers
K
what sensor wire?!? :o Mine didn't have 'em when I got 'em so I'm guessing that there are 2 different specs, one with sensor and one without... 8)
Cupra Rs have a wear sensor on the inside pad on the passenger side :wink:
I offered up one of his 18s to the side of my car today, they are bloody massive!!! No way they'd go on without arch mods!
They suit a Corrado actually 8)
I take it that's a LEON Cupra R then, not an Ibiza? That's where the difference in pads would come from then... ;)
If they are the same caliper design as the Ibiza's, then the caliper doesnt have to come off the hub to change the pad right??
As far as I know, yes it does...
you undo the 2 bolts which hold the caliper onto the carrier and then pull the pads outta the caliper... I dunno how you'd do it without removing the caliper 'cos the hub would get in the way... but I'm happy to be enlightened... 8) :D
