ross k
squeel at higher revs most likely culprit
right guys ive just completed an engine change on my corrado it now has an abf engine. Ive just finished it runs great but took it for a spin and at higher revs theirs quite a squeel from the engine bay a bit like a supercharger but only at higher revs i thinks its because ive tensioned the timing belt to tight or the power steering belt whats the most likely culprit and have you guys got any tips thanks ross
Had to use the old auxilary belt as i brought the wrong new one and i loosened that to check
Sent from my LT15i using Tapatalk 2
The bearing in the belt tensioner. Try listening to it with a metal bar held on it and pushed onto your ear.
ok will do would having the tension to tight cause it to make that noise as its a new tensioner and belt thanks ross
