sankysvr6 0 Posted April 2, 2014 Those of you that have changed your standard brake hoses to braided ones, did your front hoses come with all the mounting on them. Like the 2 rubber rings that go round them and the 1 that clips it to the shock absorber? Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 2, 2014 Somebody must know? Quote Share this post Link to post Share on other sites
clumpy1 11 Posted April 2, 2014 It does take time sometime's mate for the right person to see your post and reply. I can't help I'm afraid Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted April 2, 2014 No rubber bungs came on my Goodrich lines! Never seen any on any braided lines, only the rubber sleeve which I used to put a tywrap over without having the actual line binding. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 3, 2014 It does take time sometime's mate for the right person to see your post and reply. I can't help I'm afraid Sorry, I forget not everyone is sat in front of computer all day. LOL Will be more patient in future. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 3, 2014 No rubber bungs came on my Goodrich lines! Never seen any on any braided lines, only the rubber sleeve which I used to put a tywrap over without having the actual line binding. Thanks Sean, That's a bit rubbish, would have thought they would have come with them as standard. Well I guess its no point sending them back to the supplier, will see if I can get the old ones off and re use them. Quote Share this post Link to post Share on other sites
Dox 23 Posted April 3, 2014 I've cut that grommet off the original hose with a Stanley knife and used it on Goodrich hoses before, simply put the cut into the U shaped bracket nearest the strut with the plastic sliding sleeve (with the makers name on it) inside the grommet acting as a bush. You could super glue the cut, but I've never bothered and if the hoses are routed correctly the grommet stays in place, but you could cable tie the grommet to the strut for good measure also. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 7, 2014 Managed to get the original rubber fittings off the old brake hoses, and refitted them to the new braided hoses with out cutting them. A bit of hassle getting them off, but its doable. Just in case it helps somebody else out. Quote Share this post Link to post Share on other sites
Ninjasean2005 10 Posted April 8, 2014 As far as i am aware they don't come with rubbers attached, as I have fitted several sets of braided lines to various cars over the years and have always used the old rubbers off of the original lines. Quote Share this post Link to post Share on other sites
