-=Kris=-
VR6 Ignition leads... VW no longer supply! :(
How come you have wired them not following the grooves normally?
Might be on purpose or an error or the lead lengths? I just noticed them crossing over and am curious.
Oops my mistake ! They are the correct lengths , yes your right I have got two in the wrong grooves , I will change them over tomorrow . Well spotted . Just to clarify they do fit spot on though .
Rob
That's what happened with mine after the mechanic replaced the sparks :-(
I use the tool to remove them. Have removed them so many times and never had an issue. I'm going to stick up for the beru leads. Although I said the same about the coil pack and it broke later that week.
Same here - always use the tool although it's not like you have to do it very often
Yes please Chris!
Pm me your details and I'll get payment over to you mate. :thumbleft:
Pm sent mate. My inbox should be able to accept messages now. Cheers, Chris
You are a Forum hero matey and a nice chap to boot :salute:
Oh stop it, you're making me blush!
magnecore when setting them up (i have 8mm blue ones in my vr6) to sell at heritage i found out
The 7mm ones they do come only in black
The 8mm ones they do come only in blue
and i think the 8.5 or 10mm ones were red IIRC
I have teh blue ones fitted they just about fit int he plastics on my VR6 with some force an filing. I have some BBT black leads to go in mine as i want the original look not too sure what they are like, i was given them adn have heard good and bad things about them.
