Tigerfish
VAGCOM Error 00561 and stutter
Getting the car ready for its MOT with various bits of work. Water leak fixed, Lambda VAGCOM error cleared up, NS rear caliper changed, 288 front brake upgrade with new discs and pads, handbrake sorted. Last thing that has cropped up is a stored code for 00561, Mixture Adaptation - Static adaptation limit (add) not succeeded. I'm assuming this is likely to cause an emissions failure? I also seem to have a bit of a stutter on accelartion when taking a rigth hand bend at anything other than a crawl. Would both of these (stutter and error code) point towards a leak on the intake side? I gather there are a few possibilities, but the cornering stutter would make me think that the engive shift on the cornering is flexing the intake a bit and causing a leak (even though I can't find anything obvious). any one else had a similar thing?
Here is the tips from Ross-tech on this failure code:
00561 - Mixture Adaptation
00561 - Mixture Adaptation: Adaptation Limit (Add) Exceeded
Possible Symptoms
Engine Jolting
Increased Fuel Consumption
Poor Idling/Jolting
Reduced Boost Pressure
Possible Causes
Mass Air Flow Sensor (G70) faulty
Fuel Pressure too Low
Leaks in Intake Air System and/or Exhaust System
Injector(s) faulty (i.e. coked)
Possible Solutions
Refuel Vehicle
Check Fuel System Pressure
Check Mass Air Flow Sensor (G70)
Check Intake Air System and Exhaust System for Leaks
Check Injection Quantity
Check Injector(s)
