Hawkesybaby 10 Posted May 12, 2014 Mines up the swanny and its a diavia so i cant get inside to change the thermo resistor so looking to replace.... needs to be right hand drive, work and aircon motor for a 94 VR6 Rado thanks!!! Quote Share this post Link to post Share on other sites
fla 9 Posted May 12, 2014 you can get to the resistor panel by using an angled screwdriver. Takes a bit of patience. Once out you can remove the fuse (which will be labelled Lancia!) and replace it with a regular thermal fuse. And you don't really want to be changing the motor - that is an absolutely horrendous job. Ask me how I know! Quote Share this post Link to post Share on other sites
Hawkesybaby 10 Posted May 13, 2014 Ive managed to take the whole unit out.... but i cant get into it to change the bleedin resistor!!! thats whats in mine???? Quote Share this post Link to post Share on other sites
fla 9 Posted May 13, 2014 the resistor is in the top section of the air handling unit, just under the dash. You'll see it has 4 wires coming out from it, yellow, yellow/white, white and brown. This is the bit you need to take out. I did a thread on it - cant remember if i incorporated into my build thread though - let me check. Not meaning to be funny, but I assume you've applied 12v directly to the fan to see if it works? Quote Share this post Link to post Share on other sites
fla 9 Posted May 13, 2014 here you go: http://direct.the-corrado.net/showthread.php?t=40224 Quote Share this post Link to post Share on other sites
