carrots
repair door cards
the top edge on my front door cards is a bit poor ,drivers side the worse.the pvc is pealing from the card ive tried glue,also because ive got wind up windows i cant find any second hand.has anyone repaired theres to a good standard
What glue have you tried? I redid all the edges of mine with evo-stick impact adhesive (comes in a red tin) and it worked brilliantly.
I used the evo-stick stuff. I sprayed it on both surfaces, let it go tacky before pressing both together, clamped them together along the edge with a load of welding clamps, and left them overnight. Held up for about another day, then sagged again just above the door pull. :rolleyes:
