BILLCOR
Stunning 1996 Blackberry Corrado VR6 69kmiles DEPOSIT TAKEN
Make: VW
Model: CORRADO VR6
Colour: BLACKBERRY
Year: 1996
Engine size: 2.9
Fuel type: PETROL
Transmission: MANUAL
Mileage: 69000
MOT: 1/7/15
Tax: OCT 2014
Price: £7450ovno
Contact number/Email: 07960544154
Spec as follows:
FVWSH
INTERIOR
Black leather interior with electric Recaro front seats
Factory option gauge pod with voltage and oil pressure
New gearknob
Alpine head unit with 6 cd changer, 2 Alpine V12 amps driving front MB Quart component speakers and Alpine 10” bass sub housed in a custom made boot install
Cobra Category 1 Thatcham approved alarm
BODY
Custom red tinted rear lights
Clear side repeaters
All black badges
Remanufactured factory spec dealer number plates
Powder coated petrol tank straps
Heat shields all vapour blasted
EXHAUST
Supersprint cat back system with both rear boxes in stainless steel
New genuine VW exhaust hangers
SUSPENSION
H&R Height adjustable suspension – re-plated and powder coated springs
Bonrath uprated suspension top mounts
New front wheel bearings
New bottom ball joints
New drop links
New track rods and track rod ends
Powder coated bottom arms, subframe, driveshafts, hubs, radiator and engine support
Powder coated rear beam
All new genuine VW bolts, screws etc
Factory speedlines blasted and powder coated
BRAKES
Black Diamond grooved discs all round with Pagid pads
Powder coated backplates
Stripped and painted calipers
Goodridge braided rear brake hoses and genuine VW front flexis
Re-manufactured original brake lines from bias valve forwards
New bias valve
New master cylinder reservoir
New master cylinder to ABS pump pipes
ENGINE
Painted block
Powder coated sump with genuine new gasket
New exhaust gaskets
New inlet manifold gaskets
New cam cover gasket
Blasted and painted inlet manifolds
New water pump
Painted gearbox
Cleaned and re-plated gearbox brackets and bolts
New PAS pump
New auxiliary belt tensioner
Fully serviced with new oil filter, oil, water, PAS fluid, brake fluid
I've only had this car two weeks and now realise it was a mistake buying it... or at least thats what the wife has told me!
Its just had the tracking done at VW as there was an issue with the steering/handling, it now drives spot on, absolutely any inspection welcome, this is one of the best Corrados in the country and whilst in getting the tracking done, it had everyone in the garage round having a look, it is truly stunning.
I'll get some pics up later
SERIOUS ENQUIRIES ONLY PLEASE
Previous owner pic on RS301s
Underneath
Interior
As it stands
Can also come with these pretty rare fitment 3 peice Speedlines - 17x7.5, ET35, 5x100 which now have brand new Hankook K120 Ventus V12 Evo 205/40s fitted.
These would be an extra £1200.00
Edited by BILLCOR
More pics added
