Nick 17 10 Posted July 14, 2014 (edited) Hi guys I changed my heater matrix on Saturday which thanks to guides from people on here was not as bad as first thought just a real time consuming job. Anyway on building the car back together when I now remove the key from the ignition the fans, wipers and a water pump continue to work. I went out Sunday disconnected the battery and it stopped however after driving the car today it has started doing this again. Has anyone got any ideas before I have to go and pull all the interior apart again. Many thanks Nick Edited July 28, 2014 by Nick 17 Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted July 16, 2014 (edited) Id check relays etc if not any of them could be you ignition switch Check the earths as well Edited July 16, 2014 by Jon_vr6 Quote Share this post Link to post Share on other sites
Nick 17 10 Posted July 19, 2014 Thanks for the advice :) I changed the ignition switch as a precautionary measure and still no luck. Does anyone know what relays to look at as I am exceedingly rubbish at automotive electrics :) Thanks Nick Quote Share this post Link to post Share on other sites
Nick 17 10 Posted July 22, 2014 Anyone? Thanks Nick Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted July 22, 2014 Give them all a check to see if they are seated correctly Quote Share this post Link to post Share on other sites
Nick 17 10 Posted July 28, 2014 Just to let you guys know the problem has been solved. Relay 79 behind the glove box she moved was clicking uncontrollably. The Clicking in turn gave power to the heater fans, wipers and a pump in the engine bay. The relay has now been replaced and all is good :) Thanks for all your help guys Nick Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted July 28, 2014 Good stuff didnt think any behind the glovebox were to do with the wipers etc. Thought they were abs related Quote Share this post Link to post Share on other sites
