carrots
strange could it be coilover or wheel
took my car for an mot and its failed on the rear tyre rubbing on the jom coilover.its only doing it on one side tho.i am going to fit some 3mm spacers and just hope it dont rub on the arch
Might be that it's too low that side so affecting camber. One side (I forget which) sits further out than the other, so offset/width of the wheel could cause rubbing on the arch on that side, but it does sound like a camber problem. I'd put the money from spacers toward getting it all set up correctly first.
the camber is fixed but that doesnt mean its correct,the beam is easy to bend by clipping a back wheel.
the rear beam can be moved on the mounts, again first thing to do is alinement check.
