GlosterOx
VDO Centre Console Oil/Voltage Gauges
Hi,
Apologies firstly if this is in the wrong section, couldn't decide whether to post here or interior?
Have now got a set of the above and they have been fitted and wired in, voltage works fine. In a very old (Issue 21) Sprinter it mentions that if you want the MFA Oil Temp to still work that you need an additional extn banjo bolt (035 103 715) plus T-Piece Union (030 103 717) to fit on the filter housing.
Called the dealer and there are none in stock in the UK, so:
1) Is the above correct?
2) If yes, does anybody have them going spare?
3) Are there any alternatives I can use instead?
Thanks,
Ian.
