Jim Bowen
Fuel Tank leaks?
Corrado won't hold idle, its a VR6, been doing it ages, its ok if you hold the revs with the pedal for a short while, but runs quite rough. I haven't used it for months and always smell petrol when i walk by it.
Are there any likely hoses or seals that may be leaking at the rear end? I replaced the ones in engine bay, also tried maf, isv, coolant sensors etc to try and cure the idle and wondering if it could be fuel related.
Could be at either end of the filter Jim , this happened to me . If it was at the pump end the car would be stinking inside . Maybe worth checking inside the boot to be sure though .
