Temmsy 10 Posted September 21, 2014 Afternoon all, was wondering Ifirst any one had an ideas, my car seems pretty temprimental with starting, sometimes there is absolutely nothing for about 5 mins then a slight burst then the next turn she will turn over, but on the other hand I can jump in and it starts first time sometimes. Was wondering if anyone had had this problem before and to wether it was the starter motor or ignition please Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 21, 2014 I doubt if its the starter motor , as you will usually only get a click if its stuck . Try wiggling the key as you try to start the car , this usually points to the ignition switch . If you use the search there are many threads on starting problems ,one of them will hold the answer to your fault . Quote Share this post Link to post Share on other sites
