fla
fuse size for solar battery charger
I've run a cable from the battery into the car to connect a solar charging panel. I need to fit a fuse so what size would be recommended? I was thinking around 1amp? Charging current is not high (can't remember) but presumably it should be around 10-20% more than that?
