stretch. 0 Posted October 3, 2014 Guys, I'm swapping out my waterpump, and I've hit a bit of a rock, It appears that some of the bolts are hidden behind the oil pump pulley, is there a way to remove these without removing the pulley? If not, any tips on removing the pulley? It's a bit bloody awkward... Pics attached. Thanks for any help. Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 3, 2014 You unbolt the pump from the block, don't try to split the pump on the engine, 10mm bolts. You just need to remove the alternator, slacken the pas pump mountings and remove and lower the pump and support on something then it's all clearbolt and remove the bracket both the alternator and pas pump were attached to. once it's all clear the waterpump has 13mm bolts to the block Quote Share this post Link to post Share on other sites
stretch. 0 Posted October 6, 2014 Thanks very much :) Couldn't see a sneaky bolt under the alternator! Soooo quiet! Quote Share this post Link to post Share on other sites
