Dreadyedge 10 Posted October 7, 2014 Hey all, After a bit of advice, I recently brought a 2.0 16v and ive just started having a few probs I took the car out on Saturday and after about 10 mins of driving it all of a sudden had a funny 5 mins where it was idling roughly and was hesitant when accelerating then it went back to normal and was fine....took it out yestersay and it did the same for a few mins when 1st started then as before was fine Any idea's what the cause of this could be? Thanks in advance Quote Share this post Link to post Share on other sites
easypops 8 Posted October 7, 2014 Welcome to the forum mate, there is loads written on the fault you have with various potential causes/fixes. Have a read at this for a start, then go to advanced search and type 2.0 16v idle into it and you'll find plenty to look at http://the-corrado.net/showthread.php?t=35823&highlight=2.0+16v+kangaroo Quote Share this post Link to post Share on other sites
Dreadyedge 10 Posted October 7, 2014 Brilliant thanks very much will have a read now :) Quote Share this post Link to post Share on other sites
Hairyarse 10 Posted October 7, 2014 Welcome along mate! If yours gets worse, then this may help you as I've had a few issues with mine - http://the-corrado.net/showthread.php?t=88451 This how to may also help generally speaking - http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=25972 It's for the 1.8 KR engine, not our 2.0 9a but there's a lot of similarities you can use, such as checking for vacuum leaks, setting up the metering head flap etc (mine was filthy and way out of adjustment.) Hope that all helps - keep us updated ;) Quote Share this post Link to post Share on other sites
Dreadyedge 10 Posted October 7, 2014 Thanks Will have a look at this thread in a bit and see if I can solve it, was gonna be going into the garage soon as I seem to have an oil leak from around what I believe to be the oil pressure sensor so if I can't sort it by then I'll get the garage to have a look at that as well when it goes in Quote Share this post Link to post Share on other sites
