fla
digital display disappears with ignition
The digital displays in my clocks disappear when the ignition is switched off, similar to disconnecting the battery. Time is still correct, but i dont know about the trip meter as the car is not running yet. Any suggestions?
Only thing I can recommend is to get the multimeter out on the instrument plug and see what you find. If you find the electrics ok, it points towards the cluster being bust.
Fuse 21 blown, now sorted.
note to self: check the obvious things first before suspecting the worst!
