Will.I.Dub 11 Posted January 21, 2015 (edited) I have read the 'definitive guide on here but I'm not clear on a couple of things Which sender does the temp gauge get its signal from? Does the run on timer for the aux water pump and fans run on for 10 minutes every time the ignition is turned on and off or is it a function of temperature? Car is a 95 VR Thanks Edited January 21, 2015 by Will.I.Dub Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted January 22, 2015 Anyone? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted January 22, 2015 Temp gauge in the dash should be the yellow sender, the after run of aux pump is done on temp (which might be taken from the blue sender) Quote Share this post Link to post Share on other sites
Hairyarse 10 Posted January 22, 2015 Partsbase can often help give a clue as to which sensor does what. - http://www.partsbase.org/vw/eu/ Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted January 24, 2015 Thank you gents (unless Hairyarse is a lady):confused4: Quote Share this post Link to post Share on other sites
Hairyarse 10 Posted January 25, 2015 Thank you gents (unless Hairyarse is a lady):confused4: Nope, very much a bloke!! lol (What sort of ladies do you hang out with!! lol) Quote Share this post Link to post Share on other sites
