ausgolfer
G60 replacement coolant hoses
Hello All,
I have a 91 G60 RHD, am wanting to replace the coolant hoses.
Looking at the samco website they only do kits for LHD G60 corrados.
Is there any difference between a LHD and RHD in terms of the hoses, can I use the LHD kit?
Cheers.
i would imagine the 2 kits are different
you could try roose motorsport - there are a few of us here who run their cooling pipes
personally, i chose them over samco due to the reports i had read of samco pipes splitting
in restrospect if i was to do it again i would however not buy their jubilee clip set & would use the original VW constant tension springs
thanks gold, I'll check out roose. The standard clips are a PITA, was going to replace them with high quality regular hose clamps.
all good, back to the drawing board :D
Does anyone else know of a supplier or what the difference is between RHD/LHD hoses?
There's never been a RHD G60 specific set that I know of unfortunately.
EDIT: I wonder if after all these years it would be worth approaching somebody like Venair or similar about production?
Neil.
Edited by Riley
Isn't the layout of a Golf G60 engine the same as the Corrado G60 engine?
As I thought it was the same, so there can't be any differences in the LHD hoses I would have thought.
I'm probably missing something obvious here.
I can't imagine there being a difference in engine layout but worth checking with the suppliers.... As they are UK suppliers wouldn't they be mainly supplying right hand drive... Worth a check
Hi, did you have any luck finding out if the LHD ones will fit a RHD Corrado G60?
my names Gary by the way, I'm normally a browser not a participant on this site but thought Its about time I came out of the shadows :)
cheers
Gary
