Wayne2015
White VR6 in Windy Yorkshire! :)
no danger m8. i ended up replacing many more parts than those which were on the original list lol
plus you just cant cater for things like the heater matrix pipes collapsing when they fitted the new roose hoses - that was costly even though vince did me a half price on the labour to fit a new matrix!
however, on the plus side it meant that apart from attacking the bottom end the majority of the engine related area is now new :D lol
oh, if you consider changing your cooling hoses i would recommend using the original VW constant tension clips rather than the jubilee set the hose manf's sell (as long as it doesnt invalidate the warranty on the hoses)
FYI check out Post Office for credit card - they have a 0% transfer thingy & also a 3 month 0% on purchases! ;)
i know cause i got one 2 weeks ago so as i can put a manifold back longlife stainless system on the VR before its MOT lol
Ref the mats, not sure about the backing as I sold the car Monday! lol I think they're rubber?
Toby could check for you if he's feeling generous as he bought it from me ;)
http://the-corrado.net/showthread.php?t=89950
Wot?
Why u sell up?!!!!
Tyre garage:
Me: I heard u good, coz u ONLY use a torque wrench for final tightening of wheel?
Garage: Yes
Me: How much to replace my stretched tyres?
Garage: U know what? They don't look that stretched?
- Personally, stick with em to save money
Me: OK!
Me: That ad for 15" powder coat for £15, any good?
Garage: Jed is good
Me: How much for u to remove my tyres to power coat?
Garage: £10/tyre
So that's £25/15" power coated :)
Edited by Wayne2015
Just finding my around the forum guys
Sometimes i dont reply or thank you THINKING that by TICKING that icon on the BOTTOM RIGHT of your reply (next to REPLY WITH QUOTE) that means "I LIKE YOUR REPLY"? - no? Is it???
Blimey are they a charity??!! lol
Lol
They good people, Andy :)
Ok
More WOES from me :(
1. Can i fix this bent cover at each end bottom of the driver seat?
2. Is this normal sight?
Or there should be a cover for the fuses
And a cover by the bonnet release?
3. This NOT original fuel flap?
As it dosent seem to cover the whole fuel area
And it got no central locking bit to the flap
Hence rust around the filling area?
4. My car stalls at least once a day!
Not me stalling it, but everytime it stalls its always in neutral
(Either i just about to change gear or stationery in traffic)
Is this the fault!
(A) aluminium foil around battery connections???
(B) and what are all those RED cables going to that small BLACK box?
© or coz the LCD on dash PERMANENTLY on???
This normal?
Not drain battery?
Shall i get a new battery?
Fuel flap is correct, seat cover trim bits should have press rivets in to stop the bending out like that but chances are the splined bit at the back that keeps them in is broke. Dash lights should be off when lights are switched off, battery has obviously been on and off so many times the posts are worn, so it won't clamp tight enough, hence the foil, and finally there should be a fuse box cover which also hides the top part of the bonnet release handle, along with the trim in your footwell on the right which looks broke at the top.
Edited by seanl82
Cheers Sean
Awwww - more parts to source and ££££ then :(
As well as Timing Chain etc :( :( :(
Ref dash lights
They are off with the lights
I meant the LCD screen with the CLOCK and Mileage etc - are they suppose to display even with keys/lights out?
Thanks again :)
They display constantly but the green backlight should be off when the lights are off. If you like, I have a fusebox cover but it has a couple of holes where a previous owner has lost the correct securing clips, and just screwed a couple of self tappers in! It can't be seen, but it's yours for postage if you want it?
I love this forum! :)
Will PM ref cover - thanks Sean!
Cool - backlights are off :)
Just had lots of fun at Shell.
Ever saw a driver trying to remove his petrol cap for what seems forever?...
A lady tried to help
The staff tried
Another tried then said "try this garage, they ll do it free nowt!"
After another 10mins trying...I went to garage...
...a little elbow grease and what we all thought was the LOCKED position was in fact the UNLOCKED position...doh
I used to the fan coming on loudly to cool the engine bay after switching off...
But for the whole cabin to vibrate as if the engine is on - is something i need to get used too!
Had to pull the keys out to re-assure myself the engine was off - lol
Ok
Deffo NO First Aid box :(
No Warning Triangle :(
Good exhaust?
Anyone tell what options my car got from boot sticker?
Speaker wires (?) under rear arm rest?
Behind rear seats?
Into parcel shelf speakers
Does it look like my stock rear speakers not connected?
How do u access the rear speakers?
How many speakers my car got?
Dash 3?
2 way + a centre tweeter speaker?
How to gain access?
Size?
Door speakers
2 way?
Size?
Access?
So thats
3 on dash
2 doors
2 parcel shelf ?
How to tidy up that wooden strip bottom back of front passenger seat?
Not much space for rear passenger to put feet under front passenger seat?!!! :(
Can front passenger seat rock forward/back like the driver seat (to in increase height) ???
How to dismantle the heating panel (remove)?
And cigarette lighter socket to check connections behind?
Ok
Rear wheels has spacers,
So i can remove them and hide wheel under arches...
Front wheel look perpendicular (90degree) to road to u?
If not any idea why?
Sorry so many newbie questions ....again
That recess retangular bit just in front of gear stick mount/trim/plastic
Good place for a nice sticker?
VW / Corrado / VR6 embossed sticker?
