shawshankkid
Changing supercharger bracket relay rollers
Very easy to do:thumbleft:
Ease the tension on the belt by whatever means you see fit. (I have a tool built by a mate/think he has a couple left). You can use a large jubilee or a ratchet strap on the charger belt tensioner, or just remove the tensioner (Carefully) if you don't have the tools.
The rollers have a black cover that 'pops' off with the help of a screwdriver.
Remove caps, remove bolts.
Fit new rollers, refit bolts.
Refit plastic covers.
Refit belt.
Job done.
Neil. :thumbleft:
