Wayne2015
VR6: Which battery best?
Stalling VRs usually points to issues between the MAF, throttle, ISV and the inlet gaskets. Basically either the ISV is seized so it doesn't open in time when you drop off the throttle, or there's more air getting in than it expects and it fails to fuel sufficiently to keep it idling.
Any battery that fits will be fine. Aim for 64Ah or more if you have air-con or a big ICE setup. I would assume, personally, that the Bosch S4 and S5 are the same internally - you pay more for the longer warranty ... And what kills batteries is being discharged - so keep it topped up on a trickle charger and you'll be good for ten years or so.
