mic_VR 3 Posted February 20, 2015 Morning guys Looking for some tips or a general plan of attack for removing the downpipe from my 24v VR as I've got a lambda issue and need to weld in some new bosses. Ideally I'd like to do it with removing as little from the rest of the car as possible. And it'll be on axle stands etc? Any help appreciated! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 20, 2015 If you can't get at the DP flange bolts from underneath (you can on a ramp), you'll have to pull the front end, whip the intake off and do it that way. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted February 20, 2015 Unbolt from the cat and then there should be enough clearance for you to get some tools to the top nuts from above the engine and it should drop out with a bit of wiggling! Quote Share this post Link to post Share on other sites
