simone.IT
1992 corrado g60 to .:R32 project
Hi all, time to present my money debt. It's a 1992 corrado g60, when i bought it, i thought "need only new paint, bumpers and stop"... then was the time of, maybe a shaved/clean bay will be great...and i finished to start a r32 swap...damn! :bonk: some pics
when i bought from a friend (engine rebuilt from 40k km, horrible rieger kit, elettric recaro with new leather, and a lamborghini muricielago orange.
always burn the kit, and replaced with oem
after some month found a super occasion original us fromp bumper complete with side lights
and now after some search i've picked up in Poland a BDB 3.2 v6 engine from audi a3, 70'000km with an uncut engine loom.
and some goodies for it
i will run with a ccm gearbox, more cheap than a 02m swap and it will be enought for my drive.
Now a friend of mine from Germany is looking for me for complete vr6 front strut, alternator bracket and new alternator, starter, water pump and his ecu from a BUB engine but already ready to run on corrado swap.
hope to finish this project soon, i'm the first in Italy to do it, so i'm a little proud :cool:
Looking good! Best of luck with the conversion
hi mate, on one of many guide, i've found this your post. can u confirm that?
F plug
1-Starter wiring, Use corrado wiring
3-Alternator wiring, Corrado
G1
1-not used
2-Ambient air temp sensor, use corrado (connects to G2/2)
3-Fuel pump earth trigger, T121/65
4-Ignition live, T121/21 & Ignition coils (T40/33, fusebox A in engine bay)
5-Earth
6
7-ECU relay earth trigger, T121/23
8-fuel pump live (20A fused), Lambda sensors (T26/16 & T26/23 fusebox A) & MAF T26/9
9-
10-ECU relay ignition live, T121/3
11-Speed sender, I don't have this wire but needs putting in, think its T121/54?
12-Tacho signal, for the mk5 apparently I need to put a wire in T121/37
G2
1-Oil temp sender, use corrado
2-Ambient air temp sensor, use corrado (connects to G1/2)
3-Coolant temp sender, use corrado
4-PCV valve T40/26
5-unused
6-unused
7-unused
8-Fuel pump live, T40/37
9-Permanent live, T121/62 ECU - unsure about this as its unfused and needs a fuse, anyone confirm this?
10-Oil pressure switch, use corrado
11-Oil pressure switch, use corrado
12-
Z - Injectors T40/21r .
so F G1 G2 and Z plugs are the "only" plugs in rado fusebox that i have to convert on 24v loom? thanks
F plug
G1
1-not used
5-Earth
6
9-
G2
4-PCV valve T40/26
5-unused
6-unused
7-unused
12-
anyone can help me? :geek:
They are the main conversion plugs, there are a couple more original wires, just single or double plus. I forget what they are for, fans and something else.
hi all guys, little question, my BDB engine got the throttle body with the cooling line. Can i change with a not cooled one? i think 90° in throttle body is not a good thing for the cold air in it.
cheers
