waski186
LHD brake pump needed
lhd brake pump needed.Same was fitted in golf rally.Hopefully someone will help.Doesn`t have to come with full abs unit.If You will check the picture , this is the part under full unit with that black fluid reservoir, 5pin sensor and the cable which is going down to electric motor.
Edited by waski186
just PM me the price.And check the pump motor for me.This is that item on the bottom of the pump with 2pin cable attached.If this is running then We may have a deal.
