beastofabug 10 Posted May 18, 2015 Hi guys have a couple of broken sensors on my 16v can someone identify them so I can get replacements 1st one is on the head left corner [ATTACH]81568[/ATTACH] 2nd [ATTACH]81569[/ATTACH] Quote Share this post Link to post Share on other sites
Mawrick 0 Posted May 18, 2015 I think the second one is oil pressure switch - without knowing that engine...... The other one I'm unsure on where exactly it sits on the engine.....? Quote Share this post Link to post Share on other sites
destructiv dave 0 Posted May 18, 2015 1st one is oil temp for MFA. 2nd is oil pressure. If you unscrew it, it will have the pressure stamped on it. Quote Share this post Link to post Share on other sites
Wullie 1 Posted May 21, 2015 The first one looks like the fan run on sensor. It sits on a metal plate above the alternator Quote Share this post Link to post Share on other sites
beastofabug 10 Posted May 21, 2015 The first one looks like the fan run on sensor. It sits on a metal plate above the alternator is it a major problem if not used as cant seem to find a new one anywhere Quote Share this post Link to post Share on other sites
Wullie 1 Posted May 23, 2015 Think I got mine from Eurocarparts. There should be a part number stamped on the flats of the sensor. Quote Share this post Link to post Share on other sites
