leon263 0 Posted June 2, 2015 Any-one been able to replace the two oil pressure switches on top of the filter housing without removing the front end and radiator? Suggestions welcome, it seems a bit tight at first glance. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted June 2, 2015 Try and go in from underneath or use a deep socket. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted June 2, 2015 (edited) That's what she said... But on a serious note, it's fiddly but doable Edited June 2, 2015 by swiftkid Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted June 2, 2015 What car is it on? On the G60, you'll get away with a deep 24mm socket. Quote Share this post Link to post Share on other sites
leon263 0 Posted June 2, 2015 What car is it on? On the G60, you'll get away with a deep 24mm socket. It's on a VR6 ........ both switches on top of the filter housing. Quote Share this post Link to post Share on other sites
fla 9 Posted June 2, 2015 Remove the front headlight to get access to the connectors. If you don't have aircon you can get to them from the top with deep sockets ( as above). Alternatively you can get at them through the headlight space. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted June 2, 2015 it's fiddly but doable Fnar fnar!! :lol: Quote Share this post Link to post Share on other sites
leon263 0 Posted June 2, 2015 Remove the front headlight to get access to the connectors. If you don't have aircon you can get to them from the top with deep sockets ( as above). Alternatively you can get at them through the headlight space. Good shout on the headlight for access to the connectors, a deep socket and a selection of extension bars and universal joints should do the job. Quote Share this post Link to post Share on other sites
