Drucey
help with gearbox oil change :)
Hi all, does anybody know if the 1.8 16v corrado have gearbox oil filter? I can seem to find one so I'm guessing they don't? Also does anybody know how much oil I need and the right way of doing it? Some gold dust advise on here and is always worth asking the expets first. Thanks for any help :)
Its all in the guide, but you need 2 litres. Which of you will only use about 1.8, as you wont get it all out.
Best to loosen the filler plug on the side first, before removing the drain plug on the bottom.
