deamon90002004
corrado g60 steering help
hello, i have read in a previous post that when you go around the corner and the car wants to go on a little then little more steering angle and it goes round could be either loose bolts or worn bush on the rack
does the car have two bushes on the rack or is it one bush and then fixed metal bracket the other end?
power steering racks i've seen on the net don't help that much
Hello there,
I beleive there is just the one bush for the steering rack,
which fits to the left side complete with a U-clamp,
the right side i.e (drivers side) of the steering rack is bolted directly to the subframe and has no bush or U-clamp here.
Have a look at these photo's in the attached link:
http://the-corrado.net/showthread.php?67353-SOLD-G60-Subframe
Hope this helps.
Si
