misterbeck
Automatic gearbox interior casing
Struggling to find for late 1995 VR6 Corrado.
It is the interior black plastic casing at the base of the gear stick that i require
if someone can help. many thanks
Chuck me a fiver for postage and you can have my one - the numbers are cracked and peeling though, as with every single one ever produced!
Stone
Ok Stone, you've got a deal.
What it is that has actually happened to mine is that the thin plastic ribbon with the hole for the gear stick in the central grove has snapped in two.
It sounds like my numbers are in the same condition as yours so no need to swap them over. If you could just send me the complete plastic ribbon that would be all i need - should save on the postage too!
Much appreciated.
Stone
Hi Stone,
Do you have the thin strip/ribbon with the gear stick along along with casing?
I can send you £5.00 over as soon as you like.
cheers
Guy
