carrots
window regulator rivets
I've used standard heavy duty pop rivets in the past with no problems ....... they are not really under any undue stress as they are only holding the regulator onto the door. Part number is N 90478601 if you want the genuine thing. They appear to be used in a number of other cars so they might well still be available. I can sent you a few standard rivets if you want.
I bought one of those cheap rivet guns with the rivets and used that, was about 8yrs ago and not had an issue
