owen g60
G60 crank help
Hi guys
Im trying to find out what other engines used the same crank as the G60.
ETKA lists the part number as 026105101E... If this is true then there are loads of options.
From the limited information i have found via google search there seems to be a conflict of opinions as to whether any of the other cranks are suitable due to a wider rod and bearing shell in a g60.
Anyone able to shed some light on this?
