thesingh 0 Posted August 12, 2015 This is a whiles Im down there kind of question. I been advise to replace my front bushes, but thought I would ask whiles this is getting done is there anything else I could get changed at the same time? At the moment I was thinking of replacing the control arm as they are a little rusty. Ball joint have been done not to long ago. Any suggestions? Thanks for any help in advance. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted August 13, 2015 track rod ends, drop links, wishbone refurb, any perished gaitors Quote Share this post Link to post Share on other sites
Yandards 0 Posted August 14, 2015 If you are going to do any of the rubber bits on the front end do them all at them same time to ensure an even wear process. Cars always feel better after changing just one type of bush but that one then wears out much faster as it is taking up the wear in the other bushes. It's a larger single expense but you won't be changing bushes every few years this way. Quote Share this post Link to post Share on other sites
