johnmac
VR6 H&R cup kit issue
Hi folks,
Need some help, i bought an H&R cup kit for my VR6, they came with green springs is this correct? When trying to build them i bought new spring plates for a vr6 but the spring plates are to small and they go down the spring, any ideas?
Thanks
John
Is quite common with aftermarket springs. They are designed to fit the early style spring plate which is larger diameter.
People say you can use the early spring plates with the later top mounts (which are separate bearing and rubber bush). Must be someone on here that has that setup. Didn't seem right when i tried it.am sure it messes with the ride height.
The early plates are taller as well.
