Madjackal
Brake Caliper Change
I have had to put a new brake caliper on which is done, but do I have to bleed the entire brake system? I took the old one off and let the fluid run out into a container. Put the new caliper on and I am getting no more brake fluid through the flexible hose. Can I just bleed as required from the one side I have done and top up the fluid?
If you can be 100% sure no air has gone back up towards the master cylinder and brakes feel good then you should be okay. Personally id bledd the whole lot to make sure.
