Will.I.Dub 11 Posted September 5, 2015 Hi all, I have noticed recently while driving on rough surfaces a slight knocking/clonking coming up through the steering. Put the car up on a lift yesterday and if I grab the left hand tie rod and jerk it towards the rear of the car there's some slight movement and the knock noise. I suspect it may be the rack because when I grab the rack through the boot inboard of the inner tie rod joint I get the same result. Front bushes, bearings bjs etc have been replaced. The car has 75k miles done, the steering feels pin sharp on the road and the slightest movement of the steering wheel sees the wheels moving as they should. Is there a rebuild kit available that is more than just seals? If buying a replacement where's best to get one? The car is a '95 RHD so can anyone definitively say is it TRW or ZF? Thanks Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted September 6, 2015 Anybody? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 6, 2015 Is the rack moving? There is a bush between it and the bracket that holds it to the subframe. Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted September 6, 2015 No Jim, the rack mount bushes brackets and bolts are good Quote Share this post Link to post Share on other sites
dr_mat 0 Posted September 7, 2015 I think most VR6s came with a ZF rack, but don't think that's guaranteed as both manufacturers make a compatible part. Yes there will be a repair kit for it, whichever one it is. Quote Share this post Link to post Share on other sites
