VW_Dragon
Hi all members , a new member introduction
Hi all Corrado fanatics
Just a short introduction
I live in north west Wales , in the process of purchasing a
Corrado VR6 - 1995 - N Reg
LK4Z Bramble Metallic
Mileage around 120k
The car has a new MOT as of August / September 2015
My intention is to restore to OEM standard , is this practical and possible ?
The car obviously dose have some ware and tear over the years,some dents , paint bubbling / blistering , never had a replacement timing belt, some cloth interior work required on front seats driver side especially.
In preparation I been research for contacts for parts as well as searching the internet for replacement cloth.
Can anyone advice if it is possible to get OEM cloth code AF - Option/assist code for the seats are Q1D = Sports front seats would these be recaro seats ?
The Car option code info is as follows :-
X2B = National sales program Great Britain
B0N = Component parts set, complying with vehicle type for Great Britain, various parts
C5K = Alloy wheels 9J x 19
G0C = 5-speed manual transmission
H1V = Tires 225/45 R17
J1L = Battery 280 A (60 Ah)
1AE = Electronic differential lock (EDL/ABS)
1G9 = Space-saving spare wheel for temporary use, radial tire (5-hole)
1MV = Leather steering wheel
3AE = Right exterior mirror: flat, electrically adjustable and heated
3BF = Left exterior mirror: convex, electrically adjustable and heated
T6Q = 6-cylinder gasoline engine 2.9 L unit 021.D
3FD = Electric sliding/pop-up sunroof
9BA = W/o additional electric safety package
9HA = Without additional malfunction display
9C2 = Without special headlight activation mode but with "Coming and Leaving Home" function
8GM = Alternator 70 A
8RL = 6 speakers (passive)
8TD = Rear fog light for driving on the left
8BF = Halogen headlight for driving on the left
8WD = Integrated front fog light
1BA = Standard suspension/shock absorption
kind regards to all
Rob
Welcome to the forum.
You can put them to OEM standard but some parts are difficult to get and depends on what your starting with.
Not sure on the cloth for the seats though.
Some of those option codes don't seem correct:
C5K - 19" wheels won't fit a corrado
H1V - 17" tyres with a 19" wheel option? They only left the factory with 15" wheels
Chris
Welcome :)
They're easy enough to restore to an OE standard, but be prepared to have to wait or pay for certain pieces of trim (depending on how thorough you are) as whilst more mechanical type parts are widely available, trim and such pieces can be a mission.
You also mention a timing belt. The VR6 doesn't have a timing belt - it has a timing chain system instead. Great news you may exclaim, as it won't need replacing like a timing belt.. but alas, that's not entirely the case. Timing chains themselves stretch over time, but more pertinently the chain tensioners are a known weak spot on the VR6 motor and can wear through and ultimately fail. It would be well worth either getting the chain tensioners inspected for wear, and maybe considering getting them done regardless given the age of the car (assuming there is no history to suggest it has been done). The bad news is it's a labour intensive job with the gearbox needing to come off so not especially cheap to get done :(
Welcome. Some of the options you quoted don't sound right for a 1995 Corrado. If the seats are worn it could be a challenge to find the correct fabric. It might be easier to find a reasonable leather interior and get that repaired.
To repair my seats I bought 2 front seats in the same material I was going to use the passenger lower bolster to replace the worn out drivers side then take the material from the backs to re cover.
