16vMatt 10 Posted September 19, 2015 Recently my cooling fan has not been coming on which has led to my car overheating last week. I have tested the fan motor by wiring it to the battery with a switch and that works. The fuse hasn't blown. I did remove the part that I thought was responsible as it had corroded into nothing but I;ve misplaced it and I'm not certain of what parts to order. Suggestions please? Quote Share this post Link to post Share on other sites
fendervg 33 Posted September 19, 2015 The fans run off a couple of temp sensors and the fan control module. Did you replace or test the sender in the radiator? Quote Share this post Link to post Share on other sites
swiftkid 1 Posted September 19, 2015 Unplug sensor from rad and bridge wires, you have stage 1, 2 and an earth. If that works it's probably that sensor. If that doesn't work unplug black 2 pin sensor in thermostat housing and bridge them, that's stage 3 fan. If that doesn't work start looking for bad earth's or broken wires Quote Share this post Link to post Share on other sites
fendervg 33 Posted September 19, 2015 As above. Quote Share this post Link to post Share on other sites
16vMatt 10 Posted September 23, 2015 these are two parts I've worked out I require any names please? Quote Share this post Link to post Share on other sites
16vMatt 10 Posted September 23, 2015 these are two parts I've worked out I require any names please? The brass part in the center of the second picture is the part in referencing Quote Share this post Link to post Share on other sites
fendervg 33 Posted September 23, 2015 That's your radiator temp sender for the fan by the look of things (hard to see in context). For the plug, you can get them from VW but the part numbers can be hard to track down. You might be better off putting a call on here to see if anyone is breaking a car like yours and has the loom. Quote Share this post Link to post Share on other sites
16vMatt 10 Posted September 24, 2015 Thanks I've got the sender coming tomorrow Quote Share this post Link to post Share on other sites
