Cressa 44 Posted January 22, 2016 It doesn't seem to have the mardy clicky problems of my 2 previous corrado ones!! For me the mk3 is a better unit, still working fine, all the bolt holes and cog line up. If you have a rectangular wiring plug, it's a direct plug in. Result. Just make sure the motor is tried and tested in the correct position of your roof panel b4 fitting Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted January 22, 2016 Now to find a motor.... My town is rubbish for breakers.... So will need to check out eBay Quote Share this post Link to post Share on other sites
KARMANN 0 Posted January 23, 2016 That's good to hear Cressa. I presume to bend it you removed the part from the sunroof and bent it in a fashion so it sits down flush again? Fraser Quote Share this post Link to post Share on other sites
Cressa 44 Posted January 23, 2016 Yes mate, Removed it and bent it. Also with a little gentle heat from a blow torch to assist. It didn't need much Quote Share this post Link to post Share on other sites
